mvbighead
Over the past 3 years, I have had intermittent connectivity issues. Thinking I had a modem problem, I ended up buying a few different modems ($20 or so a piece) that I continue to swap between, but I always experience intermittent drops.
Last week, I reached out to support again, and a tech game out, checked lines, and determined that my DSL line was running through every line in my house, causing signal loss. He re-wired, tested at the port again, and noticed considerable signal quality improvement (26kpbs attainable versus the 8-11 it was getting prior). Here I'm thinking... YES YES YES, my Internet troubles are finally over.
I set up a script to basically ping google and write a log (after this repair was done) if it is unable to reach google. Sure enough, over a few days, the logs starts seeing entries. I'm thinking... maybe it was just a google thing, as it was seeming like my Internet was more reliable.
Well, this morning, I connect from my laptop for some early morning browsing, and I see 3 separate drops across a 5-10 minute span. Check the router, no WAN IP again. After a few reboots, it works again, but only for a few minutes before dropping.
At this point, i am ready to spend about $40 on a used Cisco 877 modem to see if that will at least provide useful logging to help me pinpoint the issue.
Thoughts? I would assume other DSL users out there have a relatively always on Internet connection. I can deal with a drop or two, but it's getting very frustrating. I more or less expect the Internet to drop every time I start using it.
