Originally posted by: Crazyfool
This is gonna sound really dumb but do it anyway... take out the lint filter, clean it of lint, and then run it under hot water for a minute or two.
The filter can get an invisible buildup of soap and stuff that won't allow proper air circulation making the heat element shut off.
Or your dryer could be messed up but this is worth a shot.
:beer:
Originally posted by: lavagirl669
that's a hell of a lot better than mine.....cause I don't have one
:beer:
I think tomorrow im just gonna open up the whole thing and vacuum the bejesus out of it. Other than that I'm not sure what else I can do that is within my abilities
This is what the problem was on mine, back in May. The total repair was $50 and change.Originally posted by: jaedaliu
hold down the "door close" button, and see if you can feel the air inside. (or go ahead and clean the lint areas) if there's breeze and zero heat, you got a bad heating element.
electric: no clue, I've only ever fixed gas dryers.
gas: 99% chance it's your electronic ignition that's bad. It's like a $20 part, just have to find an appliance supply store. Just gotta open up the dryer to replace it. You'll probably need some funny screwdriver heads to get to the guts of your machine, but it's an easy fix.
Originally posted by: tm37
We had an issue like this and when I pulled the front of the dryer off where the lint goes was completely clogged up.
Cleaned it out and it has been running great since. The dryer isd about 4~5 years old so now I check it about once every few months.
Check the ducting and ensure you have good airflow and then pop the front off and have a look.
Originally posted by: Blayze
Check the dryer vent and the tube going outside. They might be stopped up.
