- Mar 22, 2006
- 1,046
- 0
- 76
Hey all. Not sure if this is the best place to ask this question, but since you guys are wicked shmaht I figured it can't hurt. I have a side-by-side Whirlpool refrigerator with an icemaker. The motor that turns inside the door to break up the ice in the ice-bin is somehow getting liquid inside of it and this liquid is in turn freezing, preventing the motor from turning and dispensing ice. I can remove the motor and give it time to thaw and water will slowly start dripping out from the hole where the power plugs into the motor. Unfortunately the motor is sealed in such a way that I cannot take it apart to clean out the moisture and it won't all drip out of the power hole. I've already bought a replacement motor once and it worked for a few months, but now there's liquid in the new motor.
Anybody got any ideas on how I can get all the liquid out of this thing without breaking it open? Somebody suggested soaking it in denatured alcohol to hopefully replace the water with something with a lower freezing point. Last time I tried leaving it in a bag of rice for a week but it didn't work at all...
