Originally posted by: Abhi
The logic being that the metal in the cars body would contract and pull itself into shape??
Why wont normal ice work for this?
Originally posted by: Actaeon
Dry Ice is cheap, so I might go and try it out tomorrow out of boredom.
Nothing to lose 🙂
Thanks guys.
Missing a point here. In Alaska, the whole car is the same temp. With the dry ice, the point of contact is cold and the rest is warm (compared). In fact, this might work better on a hot day as opposed to a cold day. The metal under the ice will contract and may 'pull' itself straight. This may work.Originally posted by: SinfulWeeper
I have to call BS.
Wouldn't all cars in Alaska be dent free 😀
Nothing to lose 🙂
Thanks guys.
where do you buy dry ice ?
Originally posted by: shuan24
i doubt its going to work in the winter time. Its suppose to work on hot summer days, where the temperature difference is at the maximum. Also, I highly doubt it works on large dents. Its meant to be used on small dings.
Nothing to lose 🙂
Thanks guys.
I remember a while back you could buy some at a local grocery store (albersons, publix), I also hear you can buy some from Baskin Robbins. They use it to cool something down (I forgot, its just what I have read). Other than that, I have no idea 🙂.
As far as waiting for a hot day, you can use a blow dryer to heat a certain area up, then apply the dry ice.
I don't know the exact pricing, but from what I hear, it sounds pretty cheap. A buck or two for a block of dry ice or something.
If anyone is interested enough, I can take some before pictures, try it, and if anything happens, take after pictures. Then you guys can try it on your cars 😛.
Dry Ice = -109.3°F or -78.5°C
Regular Ice = 32°F or 0°C
Supposing that it works better with colder substances, dry ice would generally be a better choice because I don't know how to chill ice lower than -78 degrees Celcius without some lab equipment.Originally posted by: feralkid
That's the freezing (and melting) POINT, not its constant temperature.
