I'm running a wireless setup using a Linksys wireless WRT54G speedbooster router and a D-link DWL-G510 pci wireless card. The firmware is up-to-date on the router and I?m using D-link?s most recent driver and configuration utility. Every 20 to 30 minutes (randomly really) the connection will drop, and the only way to get it back is to reboot or disable/reenable the adapter. I?m currenty broadcasting SSID and using WEP, along with MAC permit. I?ve tried default settings, different channels, all sorts of different configurations the router will allow ? all resulting in the same problems. Just setting the bare minimum, no security whatsoever causes this problem. Additionally, I?ve tried allowing XP to manage the connection, which also doesn?t work. Does anyone have any thoughts about this - linksys has been less than helpful on the subject.
Thanks,
Patrick
Thanks,
Patrick
