Alright found out the spring rates. Front is 8KG and back is 7KG.
Hopefully will find some time to play with it some more but had to wrap up photos of this Mercedes S550 today and getting in a Chevy Colorado press car this week.
Thanks for adding that. I should have said something similar in my post.
I've often wondered about swapping in MS3 or other suspension onto a 5 for a fun family hauler. Glad Tuanies is paving the way! I believe Car and Driver did a full MS3 drivetrain swap into a 5 a few years back, too.
The only real reason to have a small SUV over a minivan is if you NEED all wheel drive. So few do, though, it's all about burning fuel just to think you are cool.
Astro or Safari vans come RWD or AWD.
I wish they still made them.
As for the stigma attached to the minivan some of us just like vans, period.
My parents never had a van, I work in the trades and a van keeps the toys dry. Got the first one in my 20's and had a van since. Bought a '97 RWD Safari in 2000 and a '93 the year before last.
Stigma?
http://www.astrosafari.com/viewtopic.php?f=127&t=17922&start=200#p577578
how's that for stigma???
I like the look of that van Tuanies, the dual rear sliders are something I wish my van had. Good luck at the track with it, have fun.
With spring rates like those your damper settings should be of an 8:7 ratio, or as close as you can make it. Right now your rears are considerably under-damped compared to your fronts! I can only imagine how weird the handling is as a result of that.
For sure.
I believe a number of people on Mazdas247 have done just that, even just stock MS3 springs and shocks.
So I expected to see something laughable when I looked in here... but honestly... that is pretty cool (and a nice looking van).
Note: I think the minivan is like the most particle vehicle on the planet for someone with a family. While my choice in cars is rarely confused with practical, I definitely would have no issue rocking a minivan during the week if I had kids (or another reason) to do so. More people should buy minivans instead of these stupid little "SUVs" (with verry little "S," 'U," or "V" in them).
The Astro 4WD is pretty awesome.
Yea I turned it up to 16/14 and it feels pretty good in leisure driving, but still understeers when I try to push it. I might turn it up to 16/15 and swap in the MS3 rear sway bar I have to see how that goes.
I'd highly advise using stock MS3 suspension. The front will be the same but the rear suspension is designed for the extra 400lbs the 5 weighs over the 3.
The goal is to keep it clean so only real enthusiasts will be able to spot it. People are already confused by the 6MT in it as is.
how often are you really gonna push it in your minivan? I would balance and adjust for maximum comfort when driving for a mini imo
Is this OPs only car ? sorry on my phone.
I considered adding coilovers to my sienna to improve the hwy ride. I hate the bouncing and wobble they have above 70.
Ah, thanks for the tip. I'll put the MS3 rear sway bar on soon. Turn in is fantastic where I have it now. Going to drop the back a little bit more and get an alignment done. Unfortunately I don't have the time or patience to get it corner balanced, but the struth are bottomed out.
Megan Racing said:While it is not absolutely necessary for our customers to corner balance their vehicles after installation of our fully adjustable coil-over kits, we do recommend it to maximize the performance characteristics of their suspension. The need for corner balancing depends on the intended use of the vehicle. During normal daily driving on the street, you probably would not be able to realize the benefits of a corner balanced vehicle anyway, but this is always recommend for a track-driven vehicle. Once a vehicle is corner balanced, we see a drastic improvement in the three aspects of corner weight, particularly in the cross weight percentage.
Probably just needs new shocks, if I had to guess.
DSCF0829_HDR-Edit by tuanies, on Flickrit looks like you are sitting right on top of your tires. you still have enough clearance that you don't hit your tires against the wheel well?
Manual trans, modded suspension and a good chassis. Having kids can't be so bad![]()
You plan to break the 4 second record for in your class?
Kinda like putting flames on van or air spoilers on a honda accord.
Yea it looks like its really close in the shot, but thats probably because of the gravel pit.
There's enough clearance for the wheel. I haven't noticed any rubbing or odd noises.
