I dropped a Powerbook G3. Can't get it to turn on now unless I jam and twist the power connector into the power adapter real hard.
I don't think the computer itself is messed up to badly, think it's just that the power adapter hook-up has been damaged. I looked inside the hook-up and it seems that the contact pins are bent a little bit.
Anyway, don't expect you guys can help me much, but any help/advice/test would be appreciated.
Thanks
Thanks
