k, so i accidentally dropped my 2500+ when i was sticking it in a diff pc. it bent one pin, as far as i can see, and didnt hit the core at all. so i bent the pin back as best i could, but when it sits in the socket, which it did go into w/o any force, it rocks a bit...ever so slightly tho. (on opposite corners of the proc.)
but, i dunno if the socket is just like that and it did it in the first place anyways. so i held down all four corners w/ equal pressure and then put the lever down, and course, now it doesnt budge..
i mounted my hsf and stuff and turned it on, and its fine..but should i be worried?
i was at a friends place when i did this and didnt have any other processors to test w/ to see if they rocked back and forth a little too.. and mounted the heatsink anyway cuz im not good w/ waiting...
if its necessary tho, i got a 1.33 ghz athlon here to test with if you guys think its nessary, tho im using an slk800u so its a bitch to do so..
on another note...anyone wanna buy my slk800u for like 30 bucks? i got a post in the member classified section..
thanks
thanks
