*drool* thermaltake has outdone themselves
acid16
278
AWESOME CASE!!!!!!!!
Their new case.... due at newegg Febuary 28th...
7 total case fans, entirely alluminum chassis, body and front panel!
Front USB2.0 & IEEE 1394
Front Mic and Speakers slot...
Lockable front panel
Awesome side window mod
4 channel adjustable fan speed knob built-in
Temperature LCD display built-in
Temperature alarm function!!!??
I think im in heaven. Only $213 also, that's cheaper than most Lian-Li cases...... go thermaltake!!!!!!
mudboy
498
OMG that looks like ass as only a ricer could design. Where's the Type R badge?
godmare
5,121
7 Smart Case Fan 2's, huh? I think Saddam tortures scientists with those things. Actually, I do think those are okay fans for cpu use, only because they move so much more air than the YS Tech adjustable fans. I wish the YS Tech moved more air.....
Anytime I even hear the name Thermaltake anymore, I get a bad taste in my mouth.
Noid
2,390
193
If you look at the front intake and side blowhole fans ... they are both restricted by either the HD frame, or the side panels predrilled holes.
Too many plastic parts to break also.
I cant see 'myself' buying that case.
I still like the 75 dollar Antec 1000AMG better. you can always add that LED temp thing.
ALstonLoong
1,627
the design is nice ..cool...but Kingmax is still the one i want. Runs cooler then thermaltakethe and the design is cool enough too. SImple and nice. :p
BeauJangles
13,941
Originally posted by: jarsoffart
Originally posted by: BlinderBomber
Originally posted by: OulOat
Is the chassis still a cheming clone?
Yeah. It definately is... ugly though
Well the hard drive cages are rotated like the Antec Sonata.
The button / panel layout is the same on the front... looks like it has the same dimensions as an antec.
xXgambitXx
691
<comicBookGuyVoice>Worst Case Ever</comicBookGuyVoice>
that case is all ass. just get an antec1030 clone and save your cash......and eyesight.
CLMEHNRY
8
LOL.......*at the ricer comment*...............7 x 48 dBA...........god..............despite what the packaging on my smart fan2 says, the temperature control sensor always runs at high....i use it for my cpu fan, but jesus christ, 7 of these ..............
my coolermaster is the sexiest
GrumpyMan
5,780
266
I need a slide out motherboard tray or forget it. Even Lian Li has doesn't have them in all their cases but it is a pet peeve of mine.
deepinya
1,873
The new XaserIIIs dont use smart fan2, please read up on them before bashing. These are newer and quieter fans. They run medium speed at about 30db but look at how much air they move at that RPM. Plus you get the fan control to quiet them even more if need be. If those numbers hold true then this is a sweet case indeed.
I was looking into this case and it can be found for 185-189 if you look around.
godmare
5,121
I see, I stand corrected.
Now, that having been said, I'd be willing to bet that those fans are not nearly as quiet as you might think. Thermaltake (and all manufacturers, for that matter) report their own noise figures, and depending on how those are meassured, may be quite subjective (like there's no way on earth the Smart Case Fan 2 is only 17dB turned all the way down), and even still, 7 fans at 30 dB, plus a cpu fan and power supply fan (or two if you like your power supplies extra noisy), is going to equate to one loud case.
I don't particularly care for the styling, or the drive cover, either, but that's in the eye of the beholder.
Interfire
28
I can't remember the site (I think it was hot hardware) but they said the case was quieter than the Xaser II despite the extra fans.
And the case is totally redesigned, and you better not lose the keys....
OulOat
5,769
I don't trust a lot of the little sites. A lot of them said the Volcano 9 was pretty quiet with the RPMs all the way down, no way that is true. My entire system now is quieter than the Volcano 9 at any speed.
deepinya
1,873
Yeah most manufacturers arent 100% honest with their db rating but you can always use the fan control knobs to turn them down. Having 7 fans Im sure you can get away with slowing down the fans while maintaining adequate cooling.
Edit: I also like the CPU temp readout.
Eug
24,165
1,809
OK I finally saw one of these in the store. Linky. (CAD$ prices)
It is as ugly in person as it is in the many pictures.
I think I'll go for a plain Lian-Li look, or perhaps the iStyle.
