Drivers for geforce2 Pro card for games
Muse
I'm installing my games:
Deus Ex
Max Payne
Alice
and installed Deus Ex and the single player patch and it says I should install the latest 3D driver for my card.
Can I get suggestions for drivers and where to get them? I have an MSI geforce2 Pro (831). Thanks. Right now I have the basic MSI driver that came with the card (CD) and MS Directx 8.1. I installed the Geforce Quick Tweak Utility, but haven't done anything with it (don't know how), and pushed the card a bit (core = 210 Mhz, RAM = 430 MHz). Win2k Pro reports my driver as 7.5.8.0.
When I go to play Deus Ex it says I should check to make sure I have a recent update of my video card's Direct3D driver, and it says to check at http://www.deusex.com/Direct3D.htm. But when I try to hit that page I get an error: "The page cannot be found". Thanks for any help.
<< Can I get suggestions for drivers and where to get them? >>
Try the latest 28.32 official Nvidia drivers they work fine for me,make sure you remove your old MSI drivers first before install of them.
28.32 drivers for 2K/XP .
Remember there`re plenty of other Nvidia drivers to try if you`re not happy with the 28.32 drivers.
