HI, I'VE BUYIED A takeMS USB STICK WITH 512MB.
WHEN I TRY TO USE "CARRY IT EASY v2.1.1.2" which was included in the stick
I take a BSOD:
DRIVER_IRQL_NOT_LESS_OR_EQUAL
STOP: 0x0000001 (0x0000004,0x0000003,0x0000000,0xF72BD8B2)
it also says that has a problem with nvatabus.sys
my mobo has nVidia chipset.
I tried the same application to my old computer which doesn't have everything install apart from WinXP SP2 and the application run without problems.
I've also to note that although I have only a hdd, a dvd-r, and a iomega zip, the letter on the usb is G not F. Also the icon on the driver of the usb stick is not the icon that drivers have but the icon that is used for unassociated files.
Any solution?
Any solution?
I take a BSOD:
Any solution?
Any solution?
