driver_irql_not_less_or_equal (please help again)
i am gettin this blue screen error on xp
and i thought maybe it was time for a format, so i did, but when installing XP i got blue screen errors while installing and i dont remembr which ones for sure. i thought it might be the sound card so i took that out and i installed XP fine. So im sorta assumin its cause of my sound card, anyone got any ideas?
I have a turtle beach santa cruz
some say if i switch the slot it will help, but im not sure, anyone got any ideas, and if switchin the slot does help, could you tell me why, cause i dont see how it would
Welcome to the forum!
Different slot, different IRQ's. You should definitely not have it in the first slow near the AGP card. When you formatted and installed xp, did you do the proper chipset drivers for your pc? When I had a santa cruz I never had a problem. You might also flash to the latest bios for your motherboard.
thanks for the welcome
i installed the proper chipset, i have an nforce motherboard by asus and used thier drivers and updated them
as for the sound card it was in the one next to the agp slot, and i did move it just now, one over. But i got the error again. thanks
Try a reinstall with it in a slot furthur down. See what happens. Also, make sure you have the latest santa cruz drivers, I had all kinds of problems with the ones on the CD.
exactly what is irql, cause i got the error again
if i remove stuff of the computer like this digitical optic sound output hting i never use, and an extra serial port i dont use, would it help?
cause my game port on the santa cruz always has this yellow warning sign next to it in the device manager, it always did, saids i need to free up resources
oki disabled the game port, the only thing in the deviec manager with a question mark, i got a blue screen again, but this time it didnt say driver_irql_not_less_or_equal, it just said check drivers and maybe change driver adapters, so any ideas?
alos says turn of bios caching and shadowing, whats that?
I think it's fairly important to point out that the bugcheck code in question (DRIVER_IRQL_etc..) has absolutely nothing to do with interrupts/IRQs. Basically an exception has been thrown in the kernel because a driver has accessed a resource (memory) which it currently has no access to. (search http://support.microsoft.com/ for an explanation of various bugcheck codes including this one, or read Mark Russinovich' excellent "Inside Windows xxxx" book(s))
That said, there's probably a reason this happens with your setup. If this was a common error, the device driver developers would've seen it and hopefully delayed the release (ahem)... The other day we tested Nokia's Symbian SDK which comes with a driver, and it turns out that it produces the DRIVER_IRQL_NOT_LESS_OR_EQUAL BSOD on computers with hyperthreading enabled. Many drivers (Creative probably have problems still :-( ) aren't tested on SMP rigs and will thus fail on many P4s with hyperthreading enabled too.
You're probably a sensible person who doesn't buy overpriced Intel stuff, so this probably does not apply to you. 🙂 (OTOH you could be running dual Opterons for all I know, which is a sensible thing to do, but would tickle the Nokia driver I mention)
my mobo does have onboard, i recently disbaled, and i stilll get this error
i have the latest santa cruz drivers, which arent digitally recognized by micrsoft, so i want back to an od one which is, and i still get the errors
ive disabled serials ports and usb ports, and i am still getting this error
can anyone help?
as stated above, this isn't an actual irq problem, rather, it's a memory problem. How many sticks of ram are you running? First, try using one stick at a time. If that works, try the other one, and see if it's a faulty stick. Second, you could also try uppping your memory voltage.
I've had this problem before, and it was definetly memory related. good luck.
i agree with jh it sounds like a memory problem did you try to uninstall and reinstall the card in the device manager without using the driver setup program? that might help too short of that reinstall windows usualy fixes these things as long as you have good hardware
updating the bios couldn't hurt, but I'm guessing it won't solve the problem. In the bios, if you have the option, try upping the voltage to 2.7 or so. Also, if it hasn't been done already, try setting the ram speed to "SPD", this should set the ram timings to what the stick is rated for.
Finally, trying moving the stick(s) two a different slot. It's possible that the ram slot may be faulty etc. Keep us posted.
would reinstalling windows, fix this problem in any way?
i have on stick of RAM so i cant really take it out and seeing if it works or not
I did run windows memeory test thing on it, and it passed fine so..................
and i disbaled the onboard soundcard in bios, sorta runnin out of ideas here =/
make sure you run the extended memory tests. My computer could pass the standard ones with flying colors, but test 10 or 11 in the extended tests would fail every time when I run my 2700 memory at 2700 speeds.
Almost all instances of that bugcheck (in current drivers) are not caused by actually trying to reference paged pool at a high IRQL... most driver writers have that one down by now. What normally happens when you examine the dump is that you are referencing a bogus address due to data corruption (either another driver or bad memory/cpu) and the bad address happens to be in pageable memory space (hence the error we throw).
Definately check the memory on the machine as was suggested... proc is one that's not easy to check unfortunately.
If you are bugchecking on boot (or shortly after) please post the stop code and parameters. Do this two or three times so we can verify if we are crashing in the same spot each time, or if it's the same stop code with different parameters. If it's different parameters each time you are almost guaranteed to have a hardware issue.
Problem:
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 5e044688, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000000, value 0 = read operation, 1 = write operation
Arg4: f6e74367, address which referenced memory
Recommendations:
NVENET.SYS is trying to dereference a bogus memory address. The memory address may have been valid at one point, but then either freed prior to referencing, or corrupted by another driver running on the system. I can't tell how it got that way with a minidump (not enough info) but it is a constant factor in all of the mini dumps you have. If it was a different driver referenced in each dump, I would suspect a driver is corrupting memory, but this is the same driver each time, so it's likely this is our culprit.
This is a driver provided by nForce The version you have installed is from 2002. I would suggest updating this driver.
Analysis:
kd> !analyze -v
* Bugcheck Analysis *
Arguments:
Debugging Details:
Debugger Dbgportaldb Connection::Open failed 80004005
Database Dbgportaldb not connected
ADO ERROR 80004005,11: [DBNETLIB][ConnectionOpen (Connect()).]SQL Server does not exist or access denied.
READ_ADDRESS: 5e044688
CURRENT_IRQL: 2
FAULTING_IP:
NVENET+6367
f6e74367 8b08 mov ecx,[eax]
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0xD1
LAST_CONTROL_TRANSFER: from f6e6fcdc to f6e74367
TRAP_FRAME: f78a6f0c -- (.trap fffffffff78a6f0c)
ErrCode = 00000000
eax=5e044688 ebx=83f17234 ecx=f72cb65e edx=5e044688 esi=83f17000 edi=83e8e000
eip=f6e74367 esp=f78a6f80 ebp=f78a6fa4 iopl=0 nv up ei ng nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010282
NVENET+0x6367:
f6e74367 8b08 mov ecx,[eax] ds:0023:5e044688=????????
Resetting default scope
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
f78a6fa4 f6e6fcdc 83e8e000 84cb76e8 83f171e0 NVENET+0x6367
83e8e010 00000000 00000000 00000000 00000000 NVENET+0x1cdc
FOLLOWUP_IP:
NVENET+6367
SYMBOL_STACK_INDEX: 0
FOLLOWUP_NAME: nforce
SYMBOL_NAME: NVENET+6367
MODULE_NAME: NVENET
IMAGE_NAME: NVENET.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 3de59761
STACK_COMMAND: .trap fffffffff78a6f0c ; kb
BUCKET_ID: 0xD1_NVENET+6367
Followup: nforce
kd> .trap fffffffff78a6f0c
ErrCode = 00000000
NVENET+0x6367:
kd> kv
*** Stack trace for last set context - .thread/.cxr resets it
ChildEBP RetAddr Args to Child
kd> dd eax
5e044688 ???????? ???????? ???????? ????????
5e044698 ???????? ???????? ???????? ????????
5e0446a8 ???????? ???????? ???????? ????????
5e0446b8 ???????? ???????? ???????? ????????
5e0446c8 ???????? ???????? ???????? ????????
5e0446d8 ???????? ???????? ???????? ????????
5e0446e8 ???????? ???????? ???????? ????????
5e0446f8 ???????? ???????? ???????? ????????
kd> !pool eax
Pool page 5e044688 region is Unknown
GetUlongFromAddress: unable to read from 805479d0
5e044000 is not a valid small pool allocation, checking large pool...
unable to get pool big page table - either wrong symbols or pool tagging is disabled
5e044000 is freed (or corrupt) pool
Bad allocation size @5e044000, too large
*** An error (or corruption) in the pool was detected;
*** Pool Region unknown (0x5E044000)
*** Use !poolval 5e044000 for more details.
kd> !poolval 5e044000
Pool page 5e044000 region is Unknown
Validating Pool headers for pool page: 5e044000
Pool page [ 5e044000 ] is INVALID.
kd> lmvm NVENET
start end module name
f6e6e000 f6e81c00 NVENET T (no symbols)
Loaded symbol image file: NVENET.sys
Image path: NVENET.sys
Image name: NVENET.sys
Timestamp: Wed Nov 27 20:11:13 2002 (3DE59761)
CheckSum: 00014996
ImageSize: 00013C00
Translations: 0000.04b0 0000.04e0 0409.04b0 0409.04e0
I had the most updated drivers, so i think rolling back would help
are you sure I have 2002, the package date (file name) has 2003 in it
well apparenlty at the nvidia site are more updated drivers, i been goin to asus site
sianath, i would like to thank you a lot for your help
