Hi everybody,
This is a quite bad story im about to share. Please look at my SCSI rig to see my hardware configuration.
I had win98 and win2k in dual boot on the 10k SCSI HDD and everything works fine except that I wanted to have only one OS.
So i decided to install XP on a 3.0 Go partition at the beginning of the same HDD. I used a Pro version and I delete/format in NTFS the partition. I went through installation without any problems and here I am at the first boot of XP.
Now it begins : whatever I do - nothing and reboot or install SP1 and reboot or install a software and reboot - it always come back to same BSOD just after the winXP logo on a black screen with the blue rectangles moving from left to right. It says driver_irql_not_less_or_equal and I have no more information (name of driver, address, etc).
With severals trial I finally discovered that my SCSI adapter (AHA-2940U2W) is the problem because when I put a IDE HDD and IDE CD XP install and work fine.
I've flash my adapter, my BIOS and tried to install XP with different drivers for my adapter but it always came to the same error.
I also tried to modify some BIOS paramaters like High priority PCI (my adapter is the first one), disabled onboard SCSI (have no SCSI on board but there is this option), disabled the virus chip.
Also, in the repair mode (sorry im from quebec and I dont know the exact translation for that) you can access by pressing F8 I removed the page file and then, after a reboot again in repair mode I put it back to system managed file without any success.
What I already did also : because I knew i could not reboot, I installed many softwares without reboot and I was able to use my computer for 5 weeks without any crash. I decided to shut it down because I wanted to solve the problem once and for all.
Finally, it sometimes boot after a cold reboot....but I dont know why !
Can someone help please !
