Driver upgrade problem
lifeblood
999
88
Of course I should have known, if it's not broken don't fix it!
I had my two monitors running, both using DVI. The 24" was on the 4830, and the 19" was on the onboard 3200. I was running version 10.7 (I think) of the drivers. Then I noticed Steam would update my video drivers for me. So I upgraded to v11.3, and now I can't run both monitors via digital output anymore. I can run either monitor using either DVI, no problem. I can run one monitor via DVI and the other via analog, no problem. But I can't run both on DVI although I used to be able to.
Does anyone one know if this is a bug of the new drivers or something?
