Driver problem need help
gandur
Guys
I have a C2d6400 @2.4ghz, ASUS P5B, 320 WD3200KS.....
now i had a XFX GF 7900GS which i swapped for HIS 4850.....however i am facing a driver problem....wen i put the driver Cd and start driver installation the system hangs and doesnt respond...then upon resetting i used Windows found new hardware to install the drivers....and games run fine however there is no contol center etc... so i tried to download 8.7 catalyst from amd;s website but upon starting the setup i still face the same problem....i use Win XP 32 bit SP2 and have 4 GB of RAM
robisbell
Banned
Oct 27, 2007
3,621
you needed to unisntalled thoroughly the Nvidia drivers then remove the 7900GS, then install the 4850 and then install the drivers for it.
wanderer27
2,173
15
Yeah, only now it sounds like you need to uninstall both NVidia and the ATI drivers.
You should probably run CCleaner as well to clear out some thing.
gandur
i did that actually..used CC as well didnt work....then i reinstalled feshly XP SP2 again...but the problem persisits!!!!
gandur
Cooler Master 500W real power PSU
and i face the very same problem in Vista Ultimate 64.....system freezes wen i start setup of drivers...during detecting hardware to be specific....
and a second query...i have 4Gb RAM...1+1+2 GB....but vista 64 shows it as 2.93 Gb...why????
robisbell
Banned
Oct 27, 2007
3,621
bad ram possibly, would try it with the 2 1GB sticks 1st. a 2Gb stick does not give you the DDR capability, so if it boots fine with the 2 1GB and they detect fine, then the issue may lie with your single 2GB stick.
