Hello, since some months I have a problem with one controller that I usually use, but it's working alright so I didn't paid too much attention. But now I think this is causing me a BSOTD of DPC_WATCHDOG_VIOLATION.
The problem I have is that when I press the button to start the PC, it starts fine, I can hear the HDD and all this but my 2 screens are not detecting the PC (I'm using them for like 2 months and any problem) and I have to cut the supply of the PC and turn it on again and then it's "working". But usually when I start the PC my Bios screen:
shows like 2 seconds and then continues to Windows, but now it's like that screen it's loading, and when it finishes loading, it disappear by disappearing from below to the top (like a black box moving upwards xD) then, the windows logo goes like usually do, and then is when the BSOTD comes... It restarts automatically and the same process from the start.. ok, so now what I do here is when I restart the PC cutting the supply, I start the PC and directly go to the BIOS, and then the only solution is to activate or deactivate (by doing Default settings) the Overclock, but it's not an OC problem because with the OC disabled it still happening. And when it restarts to apply the effects of the change in the Bios instead of the typical A2 number below at the right side of the screen during booting (black screen and only that appearing) is a B4 appearing, that is the first time it happens this.
I have Windows 10 64Bits installed in an SSD Samsung 350 Evo. I installed it like some months ago and any problem. the only problem is the Controller, that I think it maybe an USB problem because every time I start windows, it tells me "unable the recognize USB..."
Please, can someone help me with that problem that is killing me to start the damn PC.
PC:
Intel i5-3570k 4.2Ghz | MSI G-45 Z77 ThunderBolt | 8GB 1600Mhz DDR3 | MSI R9 290 4Gb | Samsung 350 EVO 256Gb | Nzxt Phantom 630 White | Custom MLG Water Cooling
Sorry for the bad English spelling, I'm still learning, please correct me if I wrote anything wrong.
PC:
 Facebook
Facebook Twitter
Twitter
