Driver help for Asus A8N32-SLI deluxe motherboard
oynaz
Hi guys.
I recently had to replace my motherboard, and my friend sold me his Asus A8N32-SLI deluxe motherboard cheap. He could not find his driver CD, however. "No problem," I thought. "I will simply download them off the Asus homepage". How wrong I was.
I can find the drivers, but Asus' servers times out when I try to download. The same goes for the drivers I found vigorgaming. Do one of you guys know of a link which works, or are you able to send the drivers to me if you have some?
What driver do you need exactly? You should be able to get the Nforce drivers from NVIDIA and that should have most if not all of the chipset drivers.
What you need to do is go to the website and download the BIOS from one of the FTP sites. The USA link is usually too busy so I always download from Europe. Save the file to your desktop.
Then use Asus update from Windows and select download BIOS from file. Choose the file you saved on your desktop and select save your settings and you should be done.
