- Oct 25, 2001
- 64
- 0
- 0
Hey all,
I am trying to hook up my computer display to the TV. I have a Geforce4 Ti4200 128 mb with an svideo tv out. I also have an svideo to coaxial converter so that I can connect it to my tv.
Well I have tried unsuccessfully so far to get the TV to work as a display. I have the latest nvidia driver for my card. I think the problem might be my converter cable, but I would like to rule out the possibility of a bad driver first.
The nvidia site says to make the tv out work just unplug the monitor cable so that only the S video is connected and the computer should automatically detect this once you restart and send the signal to the tv. Well its not working for me.
I am wondering if there is a driver out there which would make it easier to switch to the tv out display? I think the resolution should have something to do with it not showing up on my tv so is there a driver which would take my resolution down to the normal tv res? The current driver goes as low as 640 by 480 but no lower. Thanks in advance.
