I just got my WD 120 GB SE drive the other day and now everytime I try to format it with Windows XP Pro, it says that setup was unable to format the partition. It says to check the cables blah blah blah.......I tried formatting it with NTFS and this is when I get the problem. If I try formatting it with FAT it will work fine. How could this be? I have tried it with two different Windows XP CD's and had the same results. I have also ran it through the WD Diagnostic utility from Floppy and everything passed. It reads the drive correctly, shows everything, passes all tests, and erased fine. What could be the problem that would make the drive format in FAT, but not NTFS? Any help is appreciated!
Thanks,
Stu
Thanks,
Stu
