Drive overheated, some problems, should I still use it?
bandXtrb
Banned
May 27, 2001
2,169
The drive is a Western Digital 7200rpm 80GB. I keep my hard disk in a noise reducing enclosure outside of my case, and I point a fan on it to keep it cool. Well, I didn't know the fan was necessary to keep the drive from overheating, and when I was cleaning my desk, I pointed the fan in the wrong direction. After a few hours, my sytem crashed. I took the drive out of the enclosure, waited for it to cool down, booted up the system and was told there is "No Operating System." I ran MS-DOS scandisk: data parition had some lost clusters, OS partition had several bad sectors/clusters marked as "B." Now, I plugged in a Maxtor 80GB 5400rpm drive (recent Compusa hot deal) and installed Win2k.
My first question is, is there a way to tell if the integrity of the files on the overheated disk have been compromised? Should I trust that my files are okay and copy them, or should I try to copy from my one month old backup as much as possible? My second question is, should I continue to use the old drive, at least for the OS? It is a 7200 rpm drive, I am currently using a 5400 rpm and I can feel the difference.
db
10,575
292
If you system crashed there's going to show errors in your files.
You could try making a mirror then fire it up and do a scan to fix the files. If it works, it works, and you saved time on the install.
RSI
7,281
That doesn't belong in off topic, but anyway. It doesn't sound right. I don't know if 80GB drives heat up more than smaller ones, but I have a 7200rpm drive and it doesn't have a fan, it's on 24/7, often in heavy use, and I've never ever once had a problem and it's always been fast. However, the drive is a Quantum, not a Western Digital. ;)
Smash the drive with a huge hammer, and go buy a real hard drive. ;)
djheater
14,637
<< If you system crashed there's going to show errors in your files.
wow that's a cool idea {{file away for later}} Thanks.
