Drive cage replacments
BWMerlin
70
Hi, I recently had a drive cage in my old case at home break (don?t no how it did because it was fine when I left it and when I had a look the other day it was snapped off). Is it possible to by new drive cages and bolt/pop rivet them on? If it is it would be a good time to get a bigger one as it only has room for one cd/dvd drive and two hdd/floppies. Over all it?s a nice case and I?m planning on just moving an old pc into so that it looks newer as well as gaining things like front usb ports and side panel vent
Thanks
Zepper
18,998
Go to http://www.Evercase.com go to the page that shows all their ATX mid=tower models, pick one of the 42x2 series, go down the page to the Options. There you can get the part number for a drive cage. You can buy as many as will fit in your case. The mounting base requires only two screw holes be drilled. You can also pick up a set of HD vibe dampers for the brackets if you want. That part number is found right next to the bracket listing.
You have to call them on the phone or fax them to place a parts order as there is no eCommerce on their site - pretty dumb, IMO.
.bh.
BWMerlin
70
Thanks, ill look into them, only problem is that they will have to ship it to me overseas which will make the cost very expensive. I may just be better off removing the drive cages from another pc. This is a shame because I was hoping that I would be able to by one of those screw less removable cages which makes pulling cd/dvd and hdd out so much easier.
