Drilling a hole in a pentium pro for a key chain - help
Speedy3D!
1,794
Well, I have an old pentium pro that I want to drill a hole (or someting) to connect it to my key chain, but the thing seems to be made of somekind of extermely dense silicon or someting, and I can't drill a hole through it (I even tried burning/melting a hole through it). Nothing works, do you guys have any ideas, or do I need to get a diamond tipped drill bit? :(
lumpyhed2
32
i've been meaning to drill a hole in this here DX4-100 for a while...i'll get back to you if i'm sucessful.
compuwiz1
Admin Emeritus Elite Member
930
Here is a hint. I belive you want something that is capable of drilling ceramics, porcelan and masonary products. ;)
Speedy3D!
1,794
yeah, does anybody know the exact drill bit I would need for that? Or maybe a more powerful drill :(
kylebisme
9,396
a tungsten carbide tiped bit should do the trick, they're tough little basterds. about two or three times more expencive than a standard bit though.
celery550
469
I tried the exact same thing with one of the PPro 180's I bought off the sale/trade forum, I didn't even put a dent it the dam thing. I tried using a Dremmel and a $13 bit I got for it, I don't remember what it was made of, all it did was scratch it..sorta
scott
Speedy3D!
1,794
LOL ... Actually what I ended up doing was soldering a keychain clip onto the corner of it.
snut
er...I have a busted druon that i wanted to make a keychain buy i cant make a hold on the damn thing :( now it just sits in my car as a ordiment :(
MadRat
11,999
307
You want a sand-blast style etching wand to pulverize a hole through it. Drills will crack the ceramic. Go to a hobby store and look for these wands. Kind of expensive equipment to make a key ring. :)
