Evadman, thanks for the good advice. That's exactly what my friend who works at Firestone said, to make sure they patch it instead of plugging it. I don't know what it means, but I sure am going to insist on it. Going to discount tire tomorrow.
Thanks.
Thanks.
Basicly there are 2 ways to fix a flat. one is to stick in a piece of rubber coated in rubber cement that is about 4" long intot he puncture. All that is holding it in is the rubber cement. This is a temorary fix, but one that many concider permenant.
The other is to stick that plug in, then use a self vulcinizing rubber patch on the inside of the tire. It is 2-3" in diameter and basicy adhears to the inside of the tire permenantly,a nd much better than rubber cement ever can. This is the only real way to fully patch the tire. You can tell if they do it this way by watching what they do to the tire. If they take it off the rim, they are doing it this way. it MUST come off the rim to do this.
Be aware, that both are still a patch. your tire now has a week spot, so go easy on it. They will probably tell you not to exceed the speed limit as the patch can fail. (which is possable since the tire is not "whole" any more) but you should be fine if you keep it senseable. no 120+ runs on that tire
little more info and a pic of repairable area.
Originally posted by: The_good_guy
They plugged my tyre not patched it.. apparently it was a bit too big to be patched.. so he plugged it..
well if it holds another few montsh I will upgrade to 16" alloys and high perforamnce tyres and new shocks and springs so i will dump teh OE set.
Hi, Evadman. I usually keep it below 100, but from that diagram, I am right on the borderline.
Pic
The white shiny dot is the screw.
What do you think?
Pic
What do you think?
That is pretty damn close. Honestly, I do not know just how close to the sidewall the belts go on different brands of tires, or if there is a standard for radials. They will have to see itWhen you patch, you must patch through those belts. Only they have enough strength left with a puncture. I have seen patched sidewalls (not shoulder, sidewalls) before. It is not even close to safe, but I have seen it done. Even I will not patch a sidewall of my own tire. Shoulder yes, but not sidewall.
No one will patch it if it is the shoulder or sidewall because of legality issues, so if it is determined to be a shoulder, you are SOL.
If they are not able to patch it, then do not get just one tire. Replace both on that axle or you can get wierd handling motions, and the car will likely pull to one side, expecialy if that is a "driven" tire. If that happens, look on the bright side. You now have a full size spare.
These are $120 Bridgestone Potenza RE950's with less than 5K miles on them. I am only going to get one tire if it's punctured on the shoulder.
I thought you were asian. Why are you using the british spelling of tire?![]()
Originally posted by: TuxDave
Anyone else bothered with the spelling of tyre? Although I do sometimes write armor as armour and scepter as sceptre... so I'm partially guilty...
Originally posted by: SuperTool
I think I am going to take it to a store that doesn't have the RE950 in my size in stock.
That way there will be less pressure to buy instead of repair. I want them to be sure they can't repair it. Does it matter that the screw came in at about 45 degree angle and not straight in?
This is pissing me off big time.![]()
This $10 is just for the repair? They are still going to charge me for installation and balancing?
Originally posted by: flavio
Somebody still needs to teach the_good_guy how to change a tire. Otherwise people are going to think he's a little girl.
I know how to change a tyre.. but I just dont have the strenght or maybe the inclination to get down and dirty..
I have done it before on my old tercel.. so its not like i am a clueless geek (though in some cases like dating and relationships with women I am quite close to that).
Sometimes that X crossbar removal tool is not long enough to dislodge.. I used to carry a longer bar that would extent the leverage but i no longer do.
