OneOfTheseDays
Ok, so I switch from my previous Enermax case (you know those ones with the side window and neon light) into a new Antec Sonata. I'm wasn't expecting any sort of improvement cooling wise, I actually thought it would get worse. It turns out with the one 120mm fan suckin air out back runnin at 12 volts, I'm gettin much reduced temps.
Previous setup
1 Panaflo 80mm intake, 2 Panaflo 80 mm exhausts.
Case Temp: 35 to 40
CPU Temp: 50 - 70 C
(note these temps are high due to Abit's screwy temp. sensors).
New Setup
Stock Antec 120mm fan runnin at 12 volts
Case temp: 29-32 C
CPU Temp: 48-53 C
i'm impressed!
Previous setup
Case Temp: 35 to 40
CPU Temp: 50 - 70 C
New Setup
Case temp: 29-32 C
CPU Temp: 48-53 C
i'm impressed!
