just wanted to share my experience with you guys
What I had:
1 80mm intake fan
2 80mm exhaust fan
60mm Sunon cpu fan
Under full load my motherboard temp would rise to 38 C and my cpu temp would hit 57 C.
What I added
replaced the three generic 80mm fans with Sunon fans pushing 42.5 CFM each
cut two blowholes on the top of my case and added 2 more 80mm Sunon fans
cut two holes in the side panel of my case and added 2 92mm Sunon fans each pushing in 51 CFM
replaced Sunon cpu fan with 60mm Delta Black Label fan pushing 38 CFM
total air movement: 352.5 CFM
Now after an hour of running Unreal Tournament and encoding DivX at the same time my motherboard temp hits 29 C at the absolute max (only 4 C above room temp) and my cpu temp never gets above 46 C.
I could have bought another 256MB of RAM with the money I spent on the upgrade, but I feel the investment was well worth it. Plus, the modifications were fun and my case now has that custom look with the added holes and fans. Unfortunately, now I might have to start wearing earplugs when I go to sleep. 🙂
Shooters
What I had:
1 80mm intake fan
2 80mm exhaust fan
60mm Sunon cpu fan
What I added
Shooters
