DRAM Calculator for Ryzen 3
Ryzen has 3 Microarchitectures, Zen, Zen +, and Zen 2. People have called it Ryzen 3rd Generation because "Zen 2" is the 3rd Microarchitecture. For all Ryzen 3XXX chips you need to select "Zen 2 gen" in the "Processor" drop down menu. Also, be sure to get the latest BIOS from your MB manufacture and the newest AMD chipset Drivers (7/31/2019)
You're going to need to do a little leg work. First watch this video.
Then update your DRAM Calc to the latest version. You are running 1.6.0. There is a 1.6.0.3 out.
Then when generating your report in Thaiphoon, on the report window at the bottom, be sure to click "show in nanoseconds"
Then "import XMP" in the DRAM clac and it will list your RAM. It will not list everything correctly such as Processor type. You need to set this to Gen 2 as stated in my first response. Also, make sure everything else is correct such as DIMM mods and Motherboard.
On a side note. This is just a calculator and not a guarantee for settings. Under the SAFE calculation my system will crash after awhile.
Another vid
Instead of copying numbers by hand, export the complete HTML Report with latency in nanoseconds from Thaiphoon Burner and import that to Dram Calculator.
Another vid
Oh my, been holding off on fine tuning my RAM for my 3700x because I'm not familiar with this DRAM calculator thing and what not. Thanks for the vid share!
