Dragon+ and very bad hd preformance.....HELP!
DragonFire
I have the Dragon+ using the lastest drivers for everything under Windows XP Pro. I had the same problem before trying the via drivers as well. Sisoft Sandra puts my hd performance at 10088. A UDMA66 driver does better then that! oh yeah! I have a WD 60gig 7200rpm drive.
Maybe someone can suggest a differnet program to use? It cant be HDtech since the demo doesnt work on XP or is there a new version that does?
Ideas?
Crazee
5,736
Does it seem to be slow to you or do you think that Sisoft Sandra is giving you a false reading?
I would run it and tell you what I am getting on mine except I am running Raid so I don't think it would help.
[edit] DOH! My secondary system is not running raid so I can check it [/edit]
DragonFire
Well......XP takes longer to load on my ATA100 7200 rpm drive running on a Athlon XP 1800+ @ 1.7Ghz over my Duron 900Mhz on a ATA66 drive...
Crazee
5,736
Running Sisoft Sandra 2002 on my 1700+ w/Dragon + and WD 30GB 7200 RPM I get 19755.
