DPAD - recommendation to stop using intheory.ath.cx
Zbox
Taken from the v4.3x directory on intheory.ath.cx
100272 19990206-160316-x1w6z-[TA]Lash444.txt
100068 20040303-204436-8CKcC-[TA]Moltres.txt
100714 20040303-210404-e2vCZ-[TA]brxndxn.txt
10943 20040303-223738-66qHb-[TA]r0tt3n1.txt
409841 20040303-224621-1WGp2-[TA]aphex.txt
100951 20040303-225330-SjIoq-[TA]Moltres.txt
14034 20040303-230228-sldIA-[TA]Force-TeamGundogs.txt
12873 20040303-230309-LmhAZ-[TA]Force-TeamGundogs.txt
128203 20040303-230842-nfk7s-[TA]JonB.txt
100994 20040304-000422-6ENQv-[TA]ucdnam.txt
100206 20040304-001632-pA0Z7-[TA]z.txt
100247 20040304-010414-3MQWi-[TA]tw1164.txt
78290 20040304-015045-ACJWU-[TA]kyparrish.txt
32395 20040304-020755-9kIln-[TA]Ornery.txt
57187 20040304-022956-AXF7V-[TA]Chrishuff1.txt
43088 20040304-023851-8UhmX-[TA]JonB.txt
100467 20040304-034848-ra5a3-[TA]_Mandrill.txt
100234 20040304-040225-WqjMT-[TA]Mastertech01.txt
88274 20040304-045730-AYxjA-[TA]aphex.txt
100879 20040304-051716-yUA7C-[TA]z.txt
100798 20040304-053825-wXjDO-[TA]z.txt
100185 20040304-060124-1mLxU-[TA]magomago.txt
100929 20040304-064718-TqCnQ-[TA]Yzzim.txt
20051 20040304-064729-1m6nv-[TA]id0ntfear.txt
100192 20040304-065207-vC4l3-[TA]_Tyr.txt
100480 20040304-070959-pkcvh-[TA]aphex.txt
100074 20040304-071549-uW6Y2-[TA]Anansi.txt
100734 20040304-072226-LSc9I-[TA]beatle.txt
100894 20040304-074514-EXF98-[TA]Murphyrulez.txt
100134 20040304-081036-POAVi-[TA]tw1164.txt
100555 20040304-092743-tj9VH-[TA]DurocShark.txt
100753 20040304-095716-gfvFA-[TA]Confused.txt
100755 20040304-111057-mB29J-[TA]brxndxn.txt
100023 20040304-111306-Jwxco-[TA]MCrusty.txt
100072 20040304-111348-HgwHY-[TA]aphex.txt
100794 20040304-111748-QpbZH-[TA]z.txt
100347 20040304-112642-ldQQI-[TA]aphex.txt
100545 20040304-112953-7ojg4-[TA]z.txt
100608 20040304-113249-jAHvX-[TA]Moltres.txt
100236 20040304-122049-NuzZH-[TA]beatle.txt
100778 20040304-123537-VzgdF-[TA]Nourdmrolnmt1.txt
100906 20040304-124305-nNUMs-[TA]Anansi.txt
10836 20040304-131858-cOlnP-[TA]DaFinn.txt
100030 20040304-134100-jztaj-[TA]yukichigai.txt
100536 20040304-135100-LozMK-[TA]DanC.txt
100385 20040304-142414-s95Hn-[TA]aphex.txt
100987 20040304-151237-DGsBl-[TA]CamelToe.txt
100114 20040304-155510-VBLLt-[TA]CamelToe.txt
100231 20040304-160709-zrON0-[TA]CamelToe.txt
100645 20040304-191903-qMd4f-[TA]_Tyr.txt
30133 20040304-195203-XXHYS-[TA]_Cowboy.txt
100867 20040304-200443-sNVuq-[TA]DurocShark.txt
100470 20040304-202747-ZCTgd-[TA]Viper6.txt
100869 20040304-204927-LXp5N-[TA]_Mandrill.txt
19602 20040304-210410-MzkUX-[TA]z.txt
100360 20040304-214213-OHSWf-[TA]CADkindaGUY.txt
13724 20040304-221615-KOebz-[TA]z.txt
100502 20040304-231126-TJyas-[TA]aphex.txt
100280 20040305-002354-sI5G7-[TA]aphex.txt
631621 20040305-005739-p10UT-[TA]ScottSwingleComputers.txt
1842280 20040305-015801-YhFbF-[TA]amd.borg.txt
56119 20040305-022001-SaVQm-[TA]JonB.txt
30274 20040305-022237-8G2eT-[TA]JonB.txt
100690 20040305-023434-2sCrI-[TA]Moltres.txt
100843 20040305-025420-Q8e9C-[TA]Turin39789.txt
100935 20040305-030928-SxI5H-[TA]Murphyrulez.txt
100194 20040305-033537-32BEN-[TA]z.txt
100635 20040305-043509-aMZLg-[TA]Moltres.txt
100677 20040305-050357-OvZNC-[TA]Mastertech01.txt
2120218 20040305-051349-BLTIk-[TA]Actaeon.txt
1018 20040305-060853-s5gQk-[TA]Twioz.txt
14109 20040305-064827-Zi1Nt-[TA]_Xemus.txt
11569 20040305-080131-yf1LV-[TA]id0ntfear.txt
43193 20040305-080516-Km3Xr-[TA]Silverthorne.txt
100326 20040305-085231-mv3YV-[TA]MCrusty.txt
521011 20040305-112500-xKzwe-[TA]amd.borg.txt
100898 20040305-112631-fg1Cj-[TA]kyparrish.txt
148641 20040305-120107-NQ1eN-[TA]cooper76.txt
100134 20040305-120752-cXcVb-[TA]mordrid52.txt
100823 20040305-120850-SMKvm-[TA]crystal.txt
312718 20040305-120854-RuMhV-[TA]amd.borg.txt
100232 20040305-121452-kpZ0j-[TA]yukichigai.txt
36919 20040305-132338-toSOz-[TA]_Cowboy.txt
100959 20040305-133300-4oqJG-[TA]Mastertech01.txt
53945 20040305-134242-swu4d-[TA]z.txt
30290 20040305-144235-6ul5F-[TA]Redviffer.txt
822880 20040305-151719-HOr4Z-[TA]z.txt
100083 20040305-155841-DTjA2-[TA]Chrishuff1.txt
292633 20040305-160436-9PIGP-[TA]soni.txt
100430 20040305-161100-ESzMZ-[TA]aphex.txt
100235 20040305-161104-Rc4wG-[TA]Mastertech01.txt
25818 20040305-161231-yw0yw-[TA]Silverthorne.txt
100586 20040305-165222-20qdK-[TA]aphex.txt
11865 20040305-172213-Q2R0A-[TA]DanC.txt
100966 20040305-214554-RohhU-[TA]aphex.txt
100331 20040306-072750-M8xf1-[TA]aphex.txt
91245 21650304-223923-WtbYl-[TA]_Mandrill.txt
It appears many of our members have outstanding submissions (some are even 2 days old), totaling 14,299,917 bytes on this particular server...
I would recommend pulling the intheory.ath.cx line from servers.csv in order to avoid problems associated with this server.
-z
Why are they all from TA ? Why not other teams as well? At least I didn't see the RA on that list.
I limited my post to TA members only so that they may see if they have any results pending... There are definitely other teams out there with results stuck here as well. Log on to the ftp to see the load of files in the v4.3x directory 😛
DAYUM, there's 3 results files of mine in there!!! Only one problem with editing the servers.csv file, the next time you upload, the complete list of servers are downloaded again. So Stephen has to remove it!
count yourself lucky; I've got 10 sitting 😛
do you think if we made servers.csv read only it might not overwrite it?
in a more sorted order to see the damage:
Frist number is
the byte size of
the results.txt
file.
30133 20040304-195203-XXHYS- [TA]_Cowboy.txt
36919 20040305-132338-toSOz- [TA]_Cowboy.txt
100467 20040304-034848-ra5a3- [TA]_Mandrill.txt
100869 20040304-204927-LXp5N- [TA]_Mandrill.txt
91245 21650304-223923-WtbYl- [TA]_Mandrill.txt
100192 20040304-065207-vC4l3- [TA]_Tyr.txt
100645 20040304-191903-qMd4f- [TA]_Tyr.txt
14109 20040305-064827-Zi1Nt- [TA]_Xemus.txt
2120218 20040305-051349-BLTIk- [TA]Actaeon.txt
1842280 20040305-015801-YhFbF- [TA]amd.borg.txt
521011 20040305-112500-xKzwe- [TA]amd.borg.txt
312718 20040305-120854-RuMhV- [TA]amd.borg.txt
100074 20040304-071549-uW6Y2- [TA]Anansi.txt
100906 20040304-124305-nNUMs- [TA]Anansi.txt
409841 20040303-224621-1WGp2- [TA]aphex.txt
88274 20040304-045730-AYxjA- [TA]aphex.txt
100480 20040304-070959-pkcvh- [TA]aphex.txt
100072 20040304-111348-HgwHY- [TA]aphex.txt
100347 20040304-112642-ldQQI- [TA]aphex.txt
100385 20040304-142414-s95Hn- [TA]aphex.txt
100502 20040304-231126-TJyas- [TA]aphex.txt
100280 20040305-002354-sI5G7- [TA]aphex.txt
100430 20040305-161100-ESzMZ- [TA]aphex.txt
100586 20040305-165222-20qdK- [TA]aphex.txt
100966 20040305-214554-RohhU- [TA]aphex.txt
100331 20040306-072750-M8xf1- [TA]aphex.txt
100734 20040304-072226-LSc9I- [TA]beatle.txt
100236 20040304-122049-NuzZH- [TA]beatle.txt
100714 20040303-210404-e2vCZ- [TA]brxndxn.txt
100755 20040304-111057-mB29J- [TA]brxndxn.txt
100360 20040304-214213-OHSWf- [TA]CADkindaGUY.txt
100987 20040304-151237-DGsBl- [TA]CamelToe.txt
100114 20040304-155510-VBLLt- [TA]CamelToe.txt
100231 20040304-160709-zrON0- [TA]CamelToe.txt
57187 20040304-022956-AXF7V- [TA]Chrishuff1.txt
100083 20040305-155841-DTjA2- [TA]Chrishuff1.txt
100753 20040304-095716-gfvFA- [TA]Confused.txt
148641 20040305-120107-NQ1eN- [TA]cooper76.txt
100823 20040305-120850-SMKvm- [TA]crystal.txt
10836 20040304-131858-cOlnP- [TA]DaFinn.txt
100536 20040304-135100-LozMK- [TA]DanC.txt
11865 20040305-172213-Q2R0A- [TA]DanC.txt
100555 20040304-092743-tj9VH- [TA]DurocShark.txt
100867 20040304-200443-sNVuq- [TA]DurocShark.txt
14034 20040303-230228-sldIA- [TA]Force-TeamGundogs.txt
12873 20040303-230309-LmhAZ- [TA]Force-TeamGundogs.txt
20051 20040304-064729-1m6nv- [TA]id0ntfear.txt
11569 20040305-080131-yf1LV- [TA]id0ntfear.txt
128203 20040303-230842-nfk7s- [TA]JonB.txt
43088 20040304-023851-8UhmX- [TA]JonB.txt
56119 20040305-022001-SaVQm- [TA]JonB.txt
30274 20040305-022237-8G2eT- [TA]JonB.txt
78290 20040304-015045-ACJWU- [TA]kyparrish.txt
100898 20040305-112631-fg1Cj- [TA]kyparrish.txt
100272 19990206-160316-x1w6z- [TA]Lash444.txt
100185 20040304-060124-1mLxU- [TA]magomago.txt
100234 20040304-040225-WqjMT- [TA]Mastertech01.txt
100677 20040305-050357-OvZNC- [TA]Mastertech01.txt
100959 20040305-133300-4oqJG- [TA]Mastertech01.txt
100235 20040305-161104-Rc4wG- [TA]Mastertech01.txt
100023 20040304-111306-Jwxco- [TA]MCrusty.txt
100326 20040305-085231-mv3YV- [TA]MCrusty.txt
100068 20040303-204436-8CKcC- [TA]Moltres.txt
100951 20040303-225330-SjIoq- [TA]Moltres.txt
100608 20040304-113249-jAHvX- [TA]Moltres.txt
100690 20040305-023434-2sCrI- [TA]Moltres.txt
100635 20040305-043509-aMZLg- [TA]Moltres.txt
100134 20040305-120752-cXcVb- [TA]mordrid52.txt
100894 20040304-074514-EXF98- [TA]Murphyrulez.txt
100935 20040305-030928-SxI5H- [TA]Murphyrulez.txt
100778 20040304-123537-VzgdF- [TA]Nourdmrolnmt1.txt
32395 20040304-020755-9kIln- [TA]Ornery.txt
10943 20040303-223738-66qHb- [TA]r0tt3n1.txt
30290 20040305-144235-6ul5F- [TA]Redviffer.txt
631621 20040305-005739-p10UT- [TA]ScottSwingleComputers.txt
43193 20040305-080516-Km3Xr- [TA]Silverthorne.txt
25818 20040305-161231-yw0yw- [TA]Silverthorne.txt
292633 20040305-160436-9PIGP- [TA]soni.txt
100843 20040305-025420-Q8e9C- [TA]Turin39789.txt
100247 20040304-010414-3MQWi- [TA]tw1164.txt
100134 20040304-081036-POAVi- [TA]tw1164.txt
1018 20040305-060853-s5gQk- [TA]Twioz.txt
100994 20040304-000422-6ENQv- [TA]ucdnam.txt
100470 20040304-202747-ZCTgd- [TA]Viper6.txt
100030 20040304-134100-jztaj- [TA]yukichigai.txt
100232 20040305-121452-kpZ0j- [TA]yukichigai.txt
100929 20040304-064718-TqCnQ- [TA]Yzzim.txt
100206 20040304-001632-pA0Z7- [TA]z.txt
100879 20040304-051716-yUA7C- [TA]z.txt
100798 20040304-053825-wXjDO- [TA]z.txt
100794 20040304-111748-QpbZH- [TA]z.txt
100545 20040304-112953-7ojg4- [TA]z.txt
19602 20040304-210410-MzkUX- [TA]z.txt
13724 20040304-221615-KOebz- [TA]z.txt
100194 20040305-033537-32BEN- [TA]z.txt
53945 20040305-134242-swu4d- [TA]z.txt
822880 20040305-151719-HOr4Z- [TA]z.txt
The total is: 14,299,917 bytes worth of results
about 1 million from 3/3/04
about 4 million from 3/4/04
and 9 million from our dump day today 3/5/04
Here's some more gasoline onto the fire -
the totals per team member (the byte total of your Results.txt file)
[TA]amd.borg.txt ------- 2,676,009
[TA]Actaeon.txt ------- 2,120,218
[TA]z.txt ------- 1,513,567
[TA]aphex.txt ------- 1,502,494
[TA]ScottSwingleComputers.txt ------- 631,621
[TA]Moltres.txt ------- 502,952
[TA]Mastertech01.txt ------- 402,105
[TA]CamelToe.txt ------- 301,332
[TA]soni.txt ------- 292,633
[TA]_Mandrill.txt ------- 292,581
[TA]JonB.txt ------- 257,684
[TA]Murphyrulez.txt ------- 201,829
[TA]brxndxn.txt ------- 201,469
[TA]DurocShark.txt ------- 201,422
[TA]Anansi.txt ------- 200,980
[TA]beatle.txt ------- 200,970
[TA]_Tyr.txt ------- 200,837
[TA]tw1164.txt ------- 200,381
[TA]MCrusty.txt ------- 200,349
[TA]yukichigai.txt ------- 200,262
[TA]kyparrish.txt ------- 179,188
[TA]Chrishuff1.txt ------- 157,270
[TA]cooper76.txt ------- 148,641
[TA]DanC.txt ------- 112,401
[TA]ucdnam.txt ------- 100,994
[TA]Yzzim.txt ------- 100,929
[TA]Turin39789.txt ------- 100,843
[TA]crystal.txt ------- 100,823
[TA]Nourdmrolnmt1.txt ------- 100,778
[TA]Confused.txt ------- 100,753
[TA]Viper6.txt ------- 100,470
[TA]CADkindaGUY.txt ------- 100,360
[TA]Lash444.txt ------- 100,272
[TA]magomago.txt ------- 100,185
[TA]mordrid52.txt ------- 100,134
[TA]Silverthorne.txt ------- 69,011
[TA]_Cowboy.txt ------- 67,052
[TA]Ornery.txt ------- 32,395
[TA]id0ntfear.txt ------- 31,620
[TA]Redviffer.txt ------- 30,290
[TA]Force-TeamGundogs.txt ------- 26,907
[TA]_Xemus.txt ------- 14,109
[TA]r0tt3n1.txt ------- 10,943
[TA]DaFinn.txt ------- 10,836
[TA]Twioz.txt ------- 1,018
Grand Total 14299917
Anybody got a good feel for a Byte to Mpt conversion??
Just a ~guess at somewhere <= 30000 Mpts
let's say 23000 just to be safe
so we could have anywhere from 3,300,000(23K Mpts/KB) to 4,300,000 (30K Mpts/KB) Mpts waiting to be counted...
100KB ~20,000MPts AVERAGE..obviously some could conceivably be 100K if the transfers are high enough 😉 but 20K i've found over a period of 3 weeks is a healthy estimate
That is probably something greater than 3 Tpts but less than 4 Tpts.
and only 3.5 Tpts separates us from US-Distributed.
Sure will be nice to see that get processed.
Hi all,
I'm the owner of the FTP server at Intheory.ath.cx
My apologies for any that were stuck in there. Quite frankly, I have no idea why the results never got dumped. The server was configured correctly. I have multiple records of the datacenter logging in, but never downloading anything. Stephen uses ncFTPget to grab the files. I tested it out myself, and was able to retrieve the results. Something was going wrong on Stephen's end, my guess.
Anyhow, I've migrated to BulletProof FTP server instead of the free GuildFTP. Its higher quality. I've also tested out the ncFTPget, and it works as well.
Stephen's datacenter account is downloading the results right now. He has grabbed about 10 of the 24 mb of result files so far. I can confirm that those results have been downloaded and are no longer on my server. Although it appears he has disconnected and stopped, so he may have a cap in place about how much to download at one time. I'll let you all know when they are all flushed to the main server.
Again, my apologies for the problems.
excaliber:
A) Fine work
b) no apology necessary!
C) thanks for coming all this way to give us an update 🙂
thanks man!!
oh...and why dont you stay for the beers & the babes (it IS friday after all)...just put on your [TA] tags in user.txt ... 🙂
Hey excaliber!
Thanx for the update! 😀 and Don't worry about it, this is making for one mean dump from TA!!! 😀😀😀
oh and Welcome to the TeAm AnandTech DC forum! :beer:
Thanks. Love to crunch with you guys, but Im working DHEP over at Free-DC right now. 😉
Yeah, this Anandtech is gonna have a killer dump in the next day or so 🙂
