- Apr 5, 2005
- 12,150
- 773
- 126
I want to move my main rig is going from it's current ginormous rocketfish ATX tower to a smaller mini ITX case. The rocketfish case is going to be converted to a server build with 6 (for now) hard drives, but thats for another thread
specs:
gigabyte z68ma-d2h-b3, moving to asus p8z77i deluxe itx board
i7-2600K
CORSAIR CAFA50 120mm CPU Cooler - Dimensions 159.5 x 124.6 x 81.2mm
GTX460
samsung 240 evo SSD
1 WD black HD 4GB
SeaSonic USA SS-660XP2 dimensions 6.3" x 5.91" x 3.39"
I want the ITX case to be small, but high quality, able to fit a discrete graphics card, full size ATX PSU and at least two hard drives. budget is less than $200. I would really prefer not to buy a new heatsink but I will if it limits my choices. the machine I would have in my ITX case I imagine will always have one discrete GPU and full size ATX PSU.
Any advice on the most ideal case and fan brands for my setup? I am totally out of the loop now on what the best fans for the money are. I would like quiet but efficient fans for cooling my system.
Here are the 5 cases I was looking at
Lian Li PC-Q25B
BitFenix Phenom BFC-PHE-300-KKXKK-RP*
Corsair Obsidian Series 250D (CC-9011047-WW)
BitFenix Prodigy
Lian-Li PC-Q28B
Honestly, this is a very difficult choice since they all get good reviews and seem to fit my criteria.
Any reason to get one over the other? I always had my eyes set on the PC-Q25B when i was thinking of making an ITX server, but I think I want to keep the option to have a home server that's in an ATX case for better airflow more onboard goodies with an mATX or ATX server motherboard. I still think the Q25B is a good choice for my ITX build but what about the Q28? is it a newer version of the Q25? I really can't tell as there are tons of lian li ITX options. i'm totally confused and need some guidance!
summary:
downsizing from atx to itx
always going to have discrete GPU, and atx psu
need advice on itx case, leaning towards q25B but are there better choices for this form factor?
need advice on fans. totally out of the loop and would like something quiet with good cooling specs
thanks!
specs:
i7-2600K
GTX460
samsung 240 evo SSD
1 WD black HD 4GB
Lian Li PC-Q25B
BitFenix Prodigy
Lian-Li PC-Q28B
summary:
thanks!
