- Feb 22, 2001
- 3,044
- 544
- 136
I have been using a Define R4 case for the past year; beautiful case but large for where it sits.
I wanted a smaller case that would fit my ATX motherboard, so I purchased an Antec VSK-4000 to move into.
I knew I was downgrading the quality of the case, but I didn't know I was downgrading either sound dampening or cooling as much as I have.
At idle ( browsing web ), the machine sounds OK.
Running the Tomb Raider Benchmark, it sounded OK.
Starting up BF4 it was "Holy Sh*t this is loud".
I was running HWMonitor in the background, and for BF4, the CPU never got beyond 64 and the GPU never got beyond 67.
So - it didn't seem like it was getting "hot".
I'm not even sure which fans were causing all the noise - I suppose I will tear the side off tonight and try to narrow it down.
i5-2500K at 4.0 ( I downclocked a bit when moving into new case )
7950 running at stock speeds.
I have a Zalman Tower cooler on the CPU.
The (Antec 520w) power supply mounts at the top of this new case; the bottom of the P/S has a fan that sucks [blows?] air from inside the case.
I have an Antec 120 fan on the exhaust of the case (behind CPU), that has L/H switch ( i have set to L )
I added another Antec 120 fan on the front of the case, pulling air in ( I have it set to L as well ).
Both of the case fans are plugged into motherboard headers -- my initial guess is that it is the chasis fans making all the racket... or the 7950 going crazy and I've just never heard it before.
