Good feel for the stick? What do you mean exactly?
The synchros grinds? In a big rig you miss floating gears and your grinding gears/transmission. That's why they don't want just anyone driving their 150k tractor.
I mean, the stick moves into and out of the gear very easily when the revs are matched perfectly. (This is all without using the clutch, BTW.) If you are in gear and the revs are not matched, pulling the stick out of gear is hard.... very hard if there is a lot of torque being transmitted through the gearbox. If you match the revs (usually just blip the throttle a bit and then back off immediately while pulling the stick out of gear) then there is no torque being transmitted; the gears are spinning freely at the same rate as the engine. The stick pulls out of gear with no resistance at all.
Same with going into gear. If you are in neutral and trying to shift into gear, if the revs are not matched then it will have a lot of resistance, and if you force it and push hard enough then it will grind the synchros. If the revs are matched then you can push it into gear with no sound and no resistance; it slips right in.
So you have to get a feel for the stick and be able to put a moderate amount of pressure on the stick, enough to be able to feel the resistance but not enough to actually move things and grind the synchros. Any resistance = not matched. Slides right in/out = matched.
The synchros have little teeth on them too. As far as I can tell, this is what grinds in manual transmission cars. The synchros protect the power gears in a sense. The synchros grind, but the power gears don't. Because if the teeth don't line up on the synchro, the power gear is still disengaged.
