Downloading speed ?
alanwest09872
1,100
I pay for the 15mps download when i download the max I have ever hit was 1.81 mbps. Is there any way I can increase my speed to the 15mps that time warner has promissed us. Also I seen a motherboard with a Quad 10/100/1000Mbps thats 4 eithernet ports what is the benefit of this.
forgot to mention that I have a Timewarner cable modem a belkin router. And i ahve a abit ip-35-e hooked up and vonage hooked up to my network connection
Billb2
3,035
70
86
Just because you can receive 15mps, doesn't mean that where you're downloading from can send at that speed.
Try Speedtest.net
Muscles
424
13
Sounds to me you probably got things wrong. My guess is you mean the highest you've gotten was 1.8 MB/sec transfer rate which is ideal for 15mbps.
alanwest09872
1,100
ok my download is 4400 kbs
my upload was at 816 kbs.
that seems way lower that what is supposed to be. anyone have any ideas?
and im using newsleecher for my downloading.
and yes i meant 1.8 mb/sec thanks for the clarification muscles
Muscles
424
13
Try connecting the pc directly into the cable modem and redo the speed test. This will tell you if the router is the problem.
alanwest09872
1,100
ok I will defenetly do that. i just checked and i have run speed test in the past my max speed was almost 9000 my average was 8000 out of 5 test. including this really low 4400 one
NickOlsen8390
387
note there is a difference between 1.8Mb/s and 1.8MB/s
I have cable here in florida that is 15/2 and my max download when i download a file is around 1.8-1.9MB/s not Mb/s
Don't always trust speedtest.net your only going to see good speeds if timewarner has good routing in your area and is peered with the right people.
I have good luck with speakeasy.net/speedtest, try that, test to the closest location and see what you get.
TheKub
1,756
I pay for the 15mps download when i download the max I have ever hit was 1.81 mbps. Is there any way I can increase my speed to the 15mps that time warner has promised us.
They promised you UP TO 15Mb/s which they are providing.
NickOlsen8390
387
Yeah, there shady like that.
I know here they only guarantee 1Mb/s, Pretty crappy I think. Good thing i get more then 15mb/s i would be pissed.
