gaidensensei
Banned
I went ahead and tested my current system setup to observe the wattage consumption, minus 2 monitors.
Q6600 @2.4 stock, Abit IP35-E, 4gb DDR2 patriot stock 400mhz timings 5-5-5-12, and XFX G92 512mb ddr3 256-bit 65nm 650mhz core/972mhz memory, 1 optical drive, and 1 sata hard drive. Peripherals (KB, mouse) are separately powered.
Here is what I observed from the Kill-a-watt:
~130-140 Watts booting into Win7-64
~110-120 Watts Idle in Win7 with next to minimal background programs running
~130-159 Watts Firefox 3.6b5 running Newground's flash benchmarking with the 9 tabs loaded, probably my average usage surfing the net. It didn't increase to 159 until the end of the benchmark, at "Ultra mode" (whatever that was) pic below:
so what I derive from browsing around on the web for "G92 idle power consumption" is that the G92 takes up about ~100-130watt on idle (a huge error margin I'd add to that, since that is my current idle wattage).
If following this correctly, say I were to move down to a sapphire 4670, I effectively cut it down idle wattage to something significantly smaller, I expect something in double digits < 80 watt.
