DoubleSight DS-263N problem.
Nevandal
I purchased this monitor through newegg about 2 months ago and aside from an almost unnoticeable stuck pixel, this monitor is really amazing.
Today, I was adjusting the tilt and all of a sudden the color cut out and the entire screen turned blue. Like the red and green stopped working or something...
For some reason, if I tilt the monitor back, it does this, and if I tilt it forward, it is completely normal, full color. In between it kind of glitches.
Now, I adjusted the tilt before and I've never had this problem until today.
Anyone have any idea what might cause this?
xtknight
12,974
When you tilt it you are probably loosening the DVI/VGA connection on the back of the monitor a little.
Nevandal
Okay...problem solved. For some reason the angle the cable was coming out of the back when I tilted it there was too much tension and I think a pin was coming loose or something.
Oh well, it works now that I made sure there was a few inches of slack hanging directly under it..the cable also comes out straighter out of the connection and now bends further up the cable.
Picture perfect.
They really need to supply longer DVI cables when buying a monitor :(
