Originally posted by: Zenmervolt
Huh???
Originally posted by: Minerva
At what point in their lifespan does the crossover occur where excessive RPM can cause failure?
Those "screwy import engines" use belts, not chains you idiot. Even import engines with chains do not need the chains replaced with the engine's expected life span.Originally posted by: OrganizedChaos
as far as i knew timing chains were good for the life of the engine, the tensioner will take up any slack that develops. that may not apply to them screwey import engines te need them replaced for reasons unknown to me.
Huh???
To the best of my knowledge the answer to your question is "never".
A timing belt is good up to redline at any point during its service life. Same with a timing chain. Just that a belt's life is 30,000 - 90,000 miles while a chain will typically last the life of the engine.
Neither can be damaged by any RPM within the engine's design parameters. Honestly, there are many other things that will break if the engine is over-revved before the timing belt/chain will.
ZV
As each gets older, higher revs produce more stress. Obviously the belt will go first but it stretches more than a chain. Both can break right?
In a constant use scenario (generator) which would give more MTBF?
