I have the PAL 6035 with a denki fan on the 1.1 Tbird. Can I double up the fans , ie stack one on the other (maybe stealing the one from from my Taisol HS) to increase the airflow away from the HS?
that sounds interesting but I do believe that your total airflow when stacked would be only slightly increased ie less than the sum of the 2 individual fan outputs.
getting a more powerful fan would seem the ideal solution!
