- Jan 10, 2008
- 2,873
- 0
- 0
I currently had to swap out my Ultra 700w PSU since it seemed like something was burning on the inside, after a quick power up to see how well it was working I saw that neither of the 80mm fans was spinning at all, but for all other purposes seemed to be just fine.
So I'm probably going to go buy a spare 80mm if I can't find one lying around my house and pop it in to see if that's spinning and I just got unlucky with both fans dying at the same time (as far as I can tell, one might have been enough without me noticing) was the problem
or
If perhaps a short created by dust ruined the circuit that powers the fans since it seems isolated from when I opened up the PSU (was gonna be too much a pain to get them to cover under warranty). I didn't really examine it since I was pressed for time but I probably will tonight or tomorrow since I have a bunch of free time.
What's more likely and would this still be safe to use all the time in a system? Opinions much appreciated. (also appreciated would be how to force the PSU to power up without hooking it up to a system so I don't risk the system, but I don't particularly think it's gonna bust on me and take out a system)
or
