double dot .. vs triple dot ...
ingear
102
I often do a double dot to indicate a triple dot ..
but recently it occurred to me that some might interpret it as WTF ..
or is he illiterate or something ..
what do you think?
MongGrel
38,466
3,067
121
I think we need less spam in OT.
It was just the first thing that leapt to mind I guess.
Crono
23,720
1,503
Ellipsis is three dots. Two dots just looks like a typo...
Related: two exclamation marks (!!) instead of one or three also looks off, though it probably isn't grammatically incorrect.
Reactions: Ken g6
John Connor
22,757
619
121
what do you think?
There is only there or four, dude. And they are called ellipsis... LOL
I like how I see on some forums a whole row of ellipsis...........................
dullard
26,189
4,855
It is an ellipsis, it looks like three periods. But it isn't three periods.
… «--- Ellipsis (Alt-0133)
... «--- Three periods, means the typer tried but has no idea how to do it right
.. «--- Two periods, means the typer is an idiot who has no idea what he is doing
Look closely when typing, you will notice how the three periods doesn't look the exact same as an ellipsis. The ellipsis is one character, you can only select it as a group. Three periods are three separate characters, you can select them individually or in groups. When typing, you cannot insert any text between the dots in the ellipsis character; when typing, you can insert text between the dots of three periods. Just try replying to my text and try typing inside the ellipsis in the quote.
kranky
156
What sorcery! But Alt-0133 requires two more keystrokes than three periods, so...
^^ Ellipsical Trainer
LOL! Right on the money!
kranky
156
[borked image link, NM]
John Connor
22,757
619
121
Your image looks broken. This forum has a bad habit at that. I wonder if you used the attachment feature?
ElFenix
102,407
8,595
an ellipsis is followed by a period if the sentence ends after the ellipsis.
so it would like like: "The court finds that the defendant is guilty … ."
also note the spaces before and after the ellipsis.
nerp
9,865
105
When writing for publication, you do it this way ". . ." and it usually means you're editing out needless words in a quote.
"When we heard the explosion. . .we ran. Fast."
clamum
26,256
406
If someone uses two dots instead of three to indicate an ellipsis, I think to myself that there's a greater chance that the individual wears a helmet, and they probably Capitalize random Nouns too.
renz20003
2,714
634
el·lip·sis
iˈlipsis/
noun
  1. the omission from speech or writing of a word or words that are superfluous or able to be understood from contextual clues.
    • a set of dots indicating an ellipsis.
kranky
156
Sometimes two exclamation marks become part of history.
Reactions: Crono
Ichinisan
28,298
1,235
Double dots started getting common when people who try to double space between sentences (it's actually NOT the correct way to type in nearly all scenarios) started using Blackberry phones and smartphones. They type a period, then hit the spacebar twice. The device treats double-space as a shortcut for a period followed by a single space. Added to the period that was already typed manually, you get 2 periods and a single space.
lupi
32,539
260
I despise MS not setting Word to trigger that as a default error, would teach people to correct it themselves instead of me having to do it.
Chaotic42
35,274
2,408
Alt+0133 doesn't work on Ubuntu :astonished:
That's actually something I miss from Windows.
Edit: Apparently it's ALT+SHIFT+U. A 'u' will appear in your text box. Then type the hex code of the character, then a space.
