Live Stream: http://qik.com/dotter
If you want to chat with me and the others, download the Ventrilo client at http://ventrilo.com
Pick a username, Fill in the server info and connect, no password
Server info:
IP: verge.pure-voice.net
Port: 3194
My name is "JOSH" in ventrilo.
Well the build went ok. Live feed had to be cut off after mobo went in due to dead phone.
Everything is in the case now. I booted it up and it went into bios.
Is 21 C good temp at bios? I wanna make sure I did the thermal paste right.
Here are some pics:
http://img509.imageshack.us/img509/8919/build001qr0.jpg
http://img266.imageshack.us/img266/6630/build002oq9.jpg
http://img338.imageshack.us/img338/7809/build010ac9.jpg
http://img243.imageshack.us/img243/6215/build014at0.jpg
http://img337.imageshack.us/img337/9480/build016ff8.jpg
I will be doing cable management and vista install tomorrow live as well.
Also Miganto thanks so much for your help. Maybe you can help me tomorrow with the bios stuff.
Server info:
Port: 3194
Here are some pics:
