DOS systemname help!
funkymatt
3,919
I have a PXE server and currently use a menu to choose which image I want to boot. Each image only differs in the system.ini file under the a:\net\ directory. Is there a way to change this ini file to assign a computer name based on time or ip? This way, I can boot from one image.
Allanv
905
You should be able to edit this ini file and tell it not to ask.
Can you post the content of the ini file to look at please? Its been a long time since I used a floppy boot disk.
funkymatt
3,919
Thanks for the response Allan,
I do not specify a computername, I'm still only able to boot one machine without getting a duplicate name on the network error.
Here is a dump of the system.ini file in the net directory.
[network]
sizworkbuf=1498
filesharing=no
printsharing=no
autologon=no
computername=test
lanroot=A:\NET
username=
workgroup=SC
reconnect=0
dospophotkey=N
lmlogon=0
logondomain=SC
preferredredir=FULL
autostart=FULL
maxconnections=8
[network drivers]
netcard=e100b.dos
transport=ndishlp.sys,tcpdrv.dos,nemm.dos
devdir=A:\NET
LoadRMDrivers=yes
[386enh]
TimerCriticalSection=5000
UniqueDosPSP=TRUE
PSPIncrement=2
[Password Lists]
*Shares=A:\NET\Share000.PWL
FW_VAL=A:\NET\FW_VA000.PWL
Allanv
905
To assist me:
Are you booting images onto thin client hardware? Or is this for imaging Pc's? Or booting hard drive less Computers?
funkymatt
3,919
essentially booting systems with one drive attached, but used for testing. No resident OS. We were using floppy disks to boot, but PXE takes about 1/8 the time.
Allanv
905
Well i have checked all our PXE stuff and not one mentions a computer name. Have you tried to remove the name and boot and what PXE software are you using?
funkymatt
3,919
I'm running my PXE server from a fedora 8 box. When I boot the same image with no computername specified, i get the same duplicate workstation on the network error.
