Door won't unlock
Status
Not open for further replies.
996GT2
5,212
03 Accord. I noticed this morning that my driver's door power lock will only lock, but not unlock. If I manually unlock the door, I am able to lock it with the button in the key fob. But it won't unlock with the key fob alone. The other door locks all work fine. Does anyone know how to reset the system, or do I need a new lock actuator?
Murloc
5,382
65
if all the other doors work fine it's unlikely to be an issue that can be solved with a reset.
I found this in google: http://repairpal.com/remote-door-lockunlock-failure-363
2003 Honda Accord185,000sho50
The relay motor for the driver-side front door failed, making remote entry inoperable. Repair is costly: ~$40 part + $200 labor). Service writer at dealership says this is a common problem. Most opt to just live without remote entry (i.e., use a key).
Upvoted (4)
so your diagnosis appears correct.
996GT2
5,212
Strange. Came back to the car a few hours later and everything is working perfectly fine. Must have been a fluke.
Status
