i need my patio double doors strengthened. The door is straight, probably mdf w/ steel covering...but the too and bottom corners flex too much when you push on them.
I was thinking about getting some thin steel in a bar and then drill it into the side of the door... Its the handle side.
Those door armor kits are way too expensive
