Door Frame wood wore out
Status
Not open for further replies.
Nov 26, 2005
15,189
401
Have a rental property with an antique front door, and the wood framing for the deadbolt is wore away. How can I fix this without drilling a new hole into the door for a new deadbolt?
edit: no pics yet
Greenman
21,969
6,293
You can buy a larger strike plate that should do the job. I think home depot sells them.
Nov 26, 2005
15,189
401
Didn't think about the steel angle iron, but I did buy a longer strike and it worked. Had to chisel out a little wood and it fit. It just slightly overlapped the door latch but there was enough room for the door to close and open :)
Thanks for the help, people :)
Status
