I have an 07 Pacifica and my door is shut but the sensor flashes and I hear the beeping indicating it is open, do you think there is a fuse I could pull that would stop this? It is for the left rear door
Tried checking the sensor itself? You should be able to pull it out with little effort and check the sensor. Buying a new one would probably be less than $20 unless they really want to screw you.
Protip: don't let the other connector fall in...lol
