doom3 not capped at 60fps?
Maverick2002
I was under the impression that doom 3 was capped at 60fps but after seeing the AT article about framerates in the 100+ range I'm confused. Is it just the single player that has a "lock" at 60fps (even though the framerate can go a lot higher)?
There's a lock on frame rate but it can be disabled for benchmarking purposes. Its probably something you can toggle in console
