Doom 3 problems
GreatBarracuda
1,135
I was really looking forward to this game and now that I have it, it won't run. This is the error I get:
2998 MHz Intel CPU with MMX & SSE & SSE2 & HTT
512 MB System Memory
128 MB Video Memory
Winsock Initialized
Hostname: MACH-X
IP: 0.1.0.4
IP: 192.168.1.101
doom using MMX & SSE & SSE2 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Current search path:
C:\Program Files\Doom III/base
C:\Program Files\Doom III\base\pak005.pk4 (63 files)
C:\Program Files\Doom III\base\pak004.pk4 (5137 files)
C:\Program Files\Doom III\base\pak003.pk4 (4676 files)
C:\Program Files\Doom III\base\pak002.pk4 (6120 files)
C:\Program Files\Doom III\base\pak001.pk4 (8972 files)
C:\Program Files\Doom III\base\pak000.pk4 (2698 files)
C:\Program Files\Doom III\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
5150 strings read from strings/english.lang
Couldn't open journal files
execing editor.cfg
execing default.cfg
couldn't exec DoomConfig.cfg
couldn't exec autoexec.cfg
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
...calling CDS: ok
...created window @ 0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...attempting to use stereo
...PIXELFORMAT 5 selected
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
sound: STEREO
...using GL_ARB_multitexture
...using GL_ARB_texture_env_combine
...using GL_ARB_texture_cube_map
...using GL_ARB_texture_env_dot3
...using GL_ARB_texture_env_add
X..GL_ARB_texture_non_power_of_two not found
...using GL_ARB_texture_compression
...using GL_EXT_texture_filter_anisotropic
maxTextureAnisotropy: 16.000000
...using GL_1.4_texture_lod_bias
X..GL_EXT_shared_texture_palette not found
...using GL_EXT_texture3D
...using GL_EXT_stencil_wrap
X..GL_NV_register_combiners not found
X..GL_EXT_stencil_two_side not found
...using GL_ATI_separate_stencil
...using GL_ATI_fragment_shader
...using GL_ARB_vertex_buffer_object
...using GL_ARB_vertex_program
...using GL_ARB_fragment_program
X..EXT_depth_bounds_test not found
---------- R_NV20_Init ----------
Not available.
----- R200_Init -----
GL_NUM_FRAGMENT_REGISTERS_ATI: 6
GL_NUM_FRAGMENT_CONSTANTS_ATI: 8
GL_NUM_PASSES_ATI: 2
GL_NUM_INSTRUCTIONS_PER_PASS_ATI: 8
GL_NUM_INSTRUCTIONS_TOTAL_ATI: 16
GL_COLOR_ALPHA_PAIRING_ATI: 1
GL_NUM_LOOPBACK_COMPONENTS_ATI: 3
GL_NUM_INPUT_INTERPOLATOR_COMPONENTS_ATI: 3
FPROG_FAST_PATH
---------- R_ARB2_Init ----------
Available.
Cg not available.
---------- R_Exp_Init ----------
PARAM bloom0 = { 0.199501 };
PARAM bloom1 = { 0.176059 };
PARAM bloom2 = { 0.121004 };
PARAM bloom3 = { 0.064769 };
PARAM bloom4 = { 0.027000 };
PARAM bloom5 = { 0.008765 };
PARAM bloom6 = { 0.002216 };
PARAM bloom7 = { 0.000436 };
Available.
----- R_ReloadARBPrograms -----
glprogs/test.vfp
glprogs/test.vfp
glprogs/interaction.vfp
glprogs/bumpyEnvironment.vfp
glprogs/ambientLight.vfp
glprogs/shadow.vp
glprogs/R200_interaction.vp
glprogs/nv20_bumpAndLight.vp
glprogs/nv20_diffuseColor.vp
glprogs/nv20_specularColor.vp
glprogs/nv20_diffuseAndSpecularColor.vp
glprogs/environment.vfp
using ARB_vertex_buffer_object memory
using ARB2 renderSystem
found DLL in pak file: C:\Program Files\Doom III\base\game00.pk4/gamex86.dll
copy gamex86.dll to C:\Program Files\Doom III\base\gamex86.dll
ERROR: wrong game DLL API version
Error during initialization
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Any idea how to fix this?
Edit: I have the Catalyst 4.9, DX 9.0c and SP2, everything else is updated as well.
warcrow
11,078
11
execing default.cfg
Looks like it couldnt read two very important config files. Make sure that these two files are in the /base (i think) folder. Did you mess around with these files? If so, did you move them to a different folder?
Also, are your drivers from your chipset and videocard up to date?
warcrow
11,078
11
Originally posted by: GreatBarracuda
Um....where are these files? I can't find them...
ALL my drivers are updated.
You cannot find them? Did you try using Start button > Search? If they're not there, then you need to reinstall the game.
