- May 20, 2006
- 1,661
- 0
- 0
tried starting Doom 3 and it went back to the desktop with the following
DOOM 1.3.1302 win-x86 May 12 2005 10:40:52
2404 MHz Intel CPU with MMX & SSE & SSE2 & SSE3 & HTT
2048 MB System Memory
512 MB Video Memory
Winsock Initialized
Found interface: {CB17EAC3-276B-4EA5-AA54-40171F2FC792} Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller #2 - Packet Scheduler Miniport - 192.168.1.5/255.255.255.0
Sys_InitNetworking: adding loopback interface
doom using MMX & SSE & SSE2 & SSE3 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Loaded pk4 C:\Program Files\Doom 3\base\game00.pk4 with checksum 0x29cdb978
Loaded pk4 C:\Program Files\Doom 3\base\game01.pk4 with checksum 0xe9d5adcf
Loaded pk4 C:\Program Files\Doom 3\base\game02.pk4 with checksum 0x80401dd2
Loaded pk4 C:\Program Files\Doom 3\base\game03.pk4 with checksum 0x351c23e8
Loaded pk4 C:\Program Files\Doom 3\base\pak000.pk4 with checksum 0x28d208f1
Loaded pk4 C:\Program Files\Doom 3\base\pak001.pk4 with checksum 0x40244be0
Loaded pk4 C:\Program Files\Doom 3\base\pak002.pk4 with checksum 0xc51ecdcd
Loaded pk4 C:\Program Files\Doom 3\base\pak003.pk4 with checksum 0xcd79d028
Loaded pk4 C:\Program Files\Doom 3\base\pak004.pk4 with checksum 0x765e4f8b
Loaded pk4 C:\Program Files\Doom 3\base\pak005.pk4 with checksum 0x8ffc3621
Loaded pk4 C:\Program Files\Doom 3\base\pak006.pk4 with checksum 0x95b65ab
Loaded pk4 C:\Program Files\Doom 3\base\pak007.pk4 with checksum 0x666bdb3c
Current search path:
C:\Program Files\Doom 3/base
C:\Program Files\Doom 3\base\pak007.pk4 (38 files)
C:\Program Files\Doom 3\base\pak006.pk4 (48 files)
C:\Program Files\Doom 3\base\pak005.pk4 (63 files)
C:\Program Files\Doom 3\base\pak004.pk4 (5137 files)
C:\Program Files\Doom 3\base\pak003.pk4 (4676 files)
C:\Program Files\Doom 3\base\pak002.pk4 (6120 files)
C:\Program Files\Doom 3\base\pak001.pk4 (8972 files)
C:\Program Files\Doom 3\base\pak000.pk4 (2698 files)
C:\Program Files\Doom 3\base\game03.pk4 (2 files)
C:\Program Files\Doom 3\base\game02.pk4 (2 files)
C:\Program Files\Doom 3\base\game01.pk4 (2 files)
C:\Program Files\Doom 3\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
Addon pk4s:
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
5206 strings read from strings/english.lang
Couldn't open journal files
execing editor.cfg
execing default.cfg
couldn't exec DoomConfig.cfg
couldn't exec autoexec.cfg
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
...calling CDS: ok
...created window @ 0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...PIXELFORMAT 10 selected
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
sound: STEREO
X..GL_ARB_multitexture not found
X..GL_ARB_texture_env_combine not found
X..GL_ARB_texture_cube_map not found
X..GL_ARB_texture_env_dot3 not found
X..GL_ARB_texture_env_add not found
X..GL_ARB_texture_non_power_of_two not found
X..GL_ARB_texture_compression not found
X..GL_EXT_texture_filter_anisotropic not found
...using GL_1.4_texture_lod_bias
X..GL_EXT_shared_texture_palette not found
X..GL_EXT_texture3D not found
X..GL_EXT_stencil_wrap not found
X..GL_NV_register_combiners not found
X..GL_EXT_stencil_two_side not found
X..GL_ATI_separate_stencil not found
X..GL_ATI_fragment_shader not found
X..GL_ATI_text_fragment_shader not found
X..GL_ARB_vertex_buffer_object not found
X..GL_ARB_vertex_program not found
X..GL_ARB_fragment_program not found
ERROR: The current video card / driver combination does not support the necessary features.
Error during initialization
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Does anyone know what's wrong? I've reinstalled drivers, but it hasn't helped.
Btw, I noticed that Chronicles of Riddick also crashes to desktop. Aren't ehy both OpenGL games? If so, could that have something to do with it?
512 MB Video Memory
Winsock Initialized
Addon pk4s:
execing editor.cfg
execing default.cfg
...initializing QGL
...calling CDS: ok
sound: STEREO
