I have 2 sticks of Patriot PC4000 DDR. Rated at 250mhz. Asus A8V, Opteron 170. I figured, "Okay, as long as I'm not overclocking the memory beyond 250mhz, then it should be okay at Auto, as that'll set it to whatever the SPD specifies, right?".. WRONG.
I kept having stability problems.... I was having to set dividers down extremely low, as pushing past 200mhz at all would cause a crash.
Turns out, that my motherboard's "Auto" settings were only setting SOME things according to the SPD... A couple of values weren't being set, as I discovered with A64Info and RightMark Memory Analyzer. Even though the SPD specified values for tRC and tRFC at 200 and 250mhz, the values my system was actually using with "Auto" were MUCH lower than had been specified by the SPD.
I bumped the values up to what is recommended by SPD, and while all my problems with memory haven't gone away (it still will not hit its rated 250mhz), it HAS become much more stable.
I still can't get the memory to go much over 200mhz - but with those values "fixed", my stability at 2.7ghz has become much better....
Now, if I could just figure out what voltage I'm actually running.... A64Info reports one thing, ASUS PC Probe reports something else (much higher!!!)... Since I doubt I'm doing 2.7ghz at 1.3v, I suspect the PC Probe is more accurate. Very annoying that A64Info was wrong, as I'd used it to set my voltage to 1.5, and apparently it was running at 1.7 according to PC Probe!
Anyway... those are my adventures... And a lesson - don't depend on a motherboard to even set the memory values according to the SPD.
