SlowSpyder
- Jan 12, 2005
- 17,305
- 1,001
- 126
Depending on the magnitude of the under-clock, you are looking at the possibility of considerably reducing the heat output.
Absolutely! When I really, really pushed my CPU in voltage and clockspeed I was able to get the Kill-o-Watt to jump very near 400 watts under some CPU stress tests. On the other hand, I was able to go the other way with the voltage and had fairly decent results. I didn't lower my stock 4.4GHz, but you can probably imagine how much power I could save if I did drop it down to FX 8350 clocks and kept dropping voltage.
