Done the 4850/4870 fan fix? State your before/after idle/load temps!
nib95
997
In the following format.
GPU Make & Model: [eg Asus 4870]
Before idle: [insert here]
Before load: [insert here]
Fan speed: [insert here]
After idle: [insert here]
After load: [insert here]
If you have tried multiple fan speeds, feel free to post multiple results.
ApBp
18
GPU Make & Model: MSI 4850
Before idle: 75c
Before load: 85c+
Fan speed: Varies
After idle: 51-55c @ 40%
After load: 70-75c @ 65%
KIAman
3,342
23
Model: Visiontek HD4850
Before idle: 80c
Before load: 95c
Fan speed: 50%
After idle: 62c
After load: 80c
Fan speed: 75%
After idle: 55c
After load: 70c
lopri
13,317
691
Sapphire 4870
Before idle: 78C
Before load: 84C
Fan speed: 28%
After idle: 54C
After load: 88C
Sentry2
820
2x Powercolor 4850's
Before idle: 75C
Before load: 89C
Fan speed: 60%//100% (2 profiles, 1 gaming, 1 for desktop)
After idle: 38C
After load: 66C
MCW60R's: 32C Load @950MHz 1.51v :D
runawayprisoner
2,496
1x Powercolor 4850
Stock without 80mm exhaust fan in the back of case:
Idle: 78C
Load: 101C
Room: 31C
*After replacing thermal grease with AS5:
Idle: 75C
Load: 98C
Room: 32C
50% fan and without 80mm exhaust fan:
Idle: 55C
Load: 82C
Room: 32C
*AS5:
Idle: 54C
Load: 79C
Room: 31C
75% fan and without 80mm exhaust fan:
Idle: 53C
Load: 77C
Room: 31C
*AS5:
Idle: 54C
Load: 75C
Room: 32C
100% fan and without 80mm exhaust fan:
Idle: 51C
Load: 68C
Room: 33C
*AS5:
Idle: 51C
Load: 65C
Room: 31C
Now with exhaust fan and AS5 already applied:
Stock:
Idle: 68C
Load: 92C
Room: 31C
50%:
Idle: 47C
Load: 72C
Room: 32C
75%:
Idle: 45C
Load: 68C
Room: 32C
100%:
Idle: 43C
Load: 64C
Room: 33C
Included results with and without the exhaust fan to show you the impact of having one in your PC.
Now for a special bench: one 80mm and one 120mm exhaust (2 fans) with AS5, and fan at 50%:
Idle: 45C
Load: 68C
Room: 32C
Note: the 120mm fan is on the side of the case, about directly to the side of the card. Hmm... or should I say, it's not sucking air out of the fan, but it's sucking air out from the top of the card, whereas the 80mm is pulling out air from the CPU cooler and the back of the card.
tylerw13
220
GPU Make & Model: saphire 4870
Before idle: 80c
Before load: 88c
standard clocks on memory and core!
Fan speed: 35 percent
After idle: 50c
After load: 61c
my overclock now is 790/1100
ZickZJ
285
VisionTek 4850
Before idle 81c
Before load N/A
Fan speed 65%
After Idle 50c
After load N/A
BigMoosey74
92
GPU Make & Model: Sapphire 4870
Temps are from an average room temp of 75-80F
After thermal paste treatment but with stock fan settings:
Before idle: [78C] (10 deg drop from out of the box idle)
Before load: [never attempted a full load before fan fix]
Fan speed: [20% for idle profile]
After idle: [48-51C]
After load: [61C]
Fan speed [40% for gaming profile]
After idle [39-41C]
After load [45-48C]
Side Note: I did replace the thermal paste with OCZ Freeze. Right out of the box I was idling at 89C and I never put it under full load until after the fax fix AND thermal paste swap since I didn't want to damage the GPU in any way.
nib95
997
Good stuff guys, keep them coming. I'm trying to decide whether it's worth it for me to keep my Akasa Vortexx Neo and Zalman ram sinks or not.
runawayprisoner
2,496
Just installed Accelero S1 rev. 2 with a Noctua 120mm fan. Fan is insanely silent. To the point that I can actually hear a fly buzzing in the room now.
New temps:
Idle: 40 - 45C
Load: 61 - 65C
Room: 29C
Core and memory at 700/1100(2200).
Edit: I know this is only for fan fixes, but I thought you would be interested in an aftermarket cooler results as well.
udneekgnim
247
don't know load because 3D Mark locks up on my PC
got a VisionTek 4870 yesterday
Default Fan Speed: Idle - high 70s
100% Fan Speed: Idle - 40 C
39% Fan Speed: Idle - high 40s
I'm not sure why but switching fan speeds between 39% and 40% created a noticeable increase in noise. I didn't hear anything different between the default fan speed and 39% (have a 120 mm fan in the back and Tuniq 120 fan running at max and keep case open though), but going from 39% to 40% created a noticeable increase in noise. The fan basically revved up when going from 39% to 40%. Hearing the fan at 100% is pretty funny though.
Jul 6, 2008
135
Model: Visiontek HD4850 x 2
Before idle: 78c
Before load: 95c
Fan speed: NO FAN
After idle: 38c
After load: 53c
Fan speed: NO FAN
After idle: 48c
After load: 65c
Accelero S1's in 82F ambient.
I don't even monitor temps anymore......
Ender17
639
bookmarked for later
edit:
I adjusted my fan speed to 35% using the CCC profile method. Everything seems fine, I play a game and it's working great. I reboot and the computer won't start. I try turning it off, it won't shut off. So I turn off the PSU, then the computer is completely dead. I swap in my old video card and it boots up fine.
WTF
bryanW1995
11,144
32
New temps:
Idle: 40 - 45C
Load: 61 - 65C
Room: 29C
you really should try a new bios that unlocks the core above 700...
Avalon
7,571
178
GPU Make & Model: Visiontek 4850
Before idle: 80C
Before load: 92C
Fan speed: Variable w/fixed Powerplay BIOS
After idle: 68C
After load: 88C
